Well got the credits and now HP Tuners is working good for me. First thing I did is set the Torque Reduction back to default. It completely took care of the incredibly over-sensitive throttle! But a bit too much and softened first gear a bit too much, so I tuned the map and then smoothed it out. Took it for a test ride tonight and you would not believe the difference in how it drives. It is so much more fun now that you don't have to spend much of your concentration on making sure you don't end up in a perpetual on/off jerking throttle motion. It's just smooth now. There is a little on/off between the engine braking and the throttle as it should be.
I also killed the MIL for the emission DTC codes but kept all the others intact. Cleared the DTC and no more engine light! After the ride I have a hidden P0172 which is too rich. That might be the large injectors at idle. I'm going to set up a scan soon to see if that is when it happens. Also have more plans for the idle, that's my next big project.
