Jim, my car total weight has lost 25 lbs since the project was started - from the guy sitting behind the wheel. I haven't been at or below 250 lbs in 20 plus years. This has been a great weight loss program, maybe Lonny and Adam could state this as an extra benefit - no extra charge!Holy poop , how many hours did that take. It certainly looks cool.
430 plus holes (is that right, or did I mess up my count) @ . 8oz = 22lbs ish.
5 added.
Net savings 17 lbs
My guess is, you are going to surprise us and say you've trimmed out 30 pounds or so. I couldn't see if you drilled the side of the tunnel.
And the car weighed twice as much.It is indeed heavy. But it is not just supporting the engine. My guess is all the forces from the wheel ends end up being carried by the subframe back into the vehicle. When you have multiple forces acting in different planes/directions, you have to add up all those force components in the common direction and then add a safety factor on top of that for structure sizing criteria. The GM engineers probably made some conservative assumptions along the way as well. And steel is cheap.
Just my guess.....
that is true!And the car weighed twice as much.
Tim, you need to do IRS and takes notes so we can duplicate it.
2 lbs removedSpeed holes are happening all over, Racer X has been working overtime - when it not hot as hades in the garage - to make sure my frame doesn't get too porky. Next up in the contest is to guess how much weight was removed from my frame versus how much weight was added. I will post some photos this weekend. Here is a sneak peek.
Naaaww... that's just added internal fuel capacity.... for those loooong (over 15mins.) trips....8 lbs beer fat added during drilling process
Apparently you didn't read this post about losing 25 lbs?2 lbs removed
3 lbs steel added
The subframe was designed as most other automotive components - the design team makes a part that meets 100% of the design and performance requirements, then the lawyers and bean counters make them add 50-100% more margin (and weight) to the part for corporate insurance reasons. So the subframe is somewhere around 150-200% of the design requirements for a 3200lb. car. So bolting the subframe into a 1600lb car, the subframe is 300-400% of the design that would be necessary for the Goblin.It is indeed heavy. But it is not just supporting the engine. My guess is all the forces from the wheel ends end up being carried by the subframe back into the vehicle. When you have multiple forces acting in different planes/directions, you have to add up all those force components in the common direction and then add a safety factor on top of that for structure sizing criteria. The GM engineers probably made some conservative assumptions along the way as well. And steel is cheap.
Just my guess.....
They are already IRS.... But I would love a different rear suspension design. McPherson strut design leaves a lot to be desired.Tim, you need to do IRS and takes notes so we can duplicate it.
Ran out of time over the weekend, the honey-do list got in the way of taking pictures. I will get them this coming weekend and will see how imaginative the weight guessing can be. And start counting those holes, since the most accurate number will earn you points!Thanks Lonny, that's probably another 5-6 ounces for that plate. All those metal chips are like snowflakes - they add up quick and become pounds after a while! I'll let the guesses keep coming in and betting some will change with the additional pics this weekend. BTW, steel is 0.285 lbs per cubic inch for those doing the numbers thing.
