devianteng
Yes, these purple wires were fog light wires. Video 7, around 1:50 into the video we extend 1 wire toward the BCM and the other stays near the fuse box. It's mentioned these can be used for accessories. So I guess they are switched power wires, from the fog light switch (but I guess I don't know where that switch is/will be in the Goblin). These would be good for the low power side of a relay, depending on what needed to be powered.The purple wire is typically the fog light wire, but not sure where you got two of them. It isn't hot unless the trigger wire from the original switch is grounded. I think the DF supplied switches have that included if you got that option. Basically the fog light wires are only good for lights without doing some other relay grounding/jumping. The Red/white should be switched power I think.
So that must mean the red w/ white wire is a key-on power wire. Makes sense to me.
I've had trouble deciding that for myself and hoping to get feedback. The redrilled hubs from DF, are these new hubs or refurb? if new, I'd expect there is a reasonably good chance they will last for at least 50k "reasonable" street miles but getting replacements redrilled could definitely present a challenge in the future. Worthwhile risk, IMO. Where I really need help is around optimal wheel size, ideal offset, and recommended tire width (square setup, or smaller upfront, etc). Things I definitely need to do more research into.You will have to decide the trade off of redrilled hubs for wheel choice and the availability of replacement hubs if you need them without getting them drilled.
