Cobalt SS tire stock size is 225/40-18, which is a 25.1 inch tall tire - this can vary by 0.1 inch depending upon manufacturer. This is a 3% difference in speedometer reading - slower.
Mostly correct. That’s how I played it. You have to remember, it’s easier and cheaper to go with a common tire too. Plus, the 275 are 1.2” wider, but that will only gain you 1.2 in width overall. Half of the width gain will be inside and the other half outside. Either way. There’s still a 255 in between there if you want to add that to your equation.@Rttoys Thanks for the great info. I've got several 17x9 wheels I'm looking at, and for tires I'm looking at the Toyo R1R.
Based on your feedback, I'm currently considering 275/40R17 on the rear and 245/45R17 on the front. Both tires are 25.7" overall diameter, which is the same size as the factory Cobalt (which is also a 245/45R17 I believe). Speedo should still be accurate.
The 275 is ~1.2" wider than the 245, so that means I'd gain ~2.4" width in the rear, which I think makes it close to the same overall width as the front. In theory it seems like a good setup, yeah?
Oh thanks! I referenced that thread a lot, but must had missed your spreadsheet. Would had been nice to filter through that while I was going through all this, haha. I did get my wheels ordered (what I mentioned above), but tires are still undecided. Not in a super hurry to get that figured out yet. I'll get my wheels added to the doc!Not to throw any more ideas on your nearly made decision, but I also just finished up the google sheet for everyone's tires and wheels you can check out in the tires/wheels section. Once you make your decision too, can add your info in as well! I'm surprised the different variety of everyone's choices in wheels, tires, offsets... it's a lot of neat data. Nearly no 2 are identical.
Tires and Wheels List Updated on 3/25/2020
Guess I don’t know much about wheels, if stock size for the SS is 18 why do so many run 17’s ? .dfkitcar.com
Did you select your powder with your coating guy and he then ordered what you needed? Estimated the amount and all?February 21, 2023
Also heard that my powder coat guy got the Illusion Blaze in
Yeah, my guy has like 30 different swatch bundles to look through (hundreds of color samples), across Prismatic and Columbia powders. I took one of the tunnel cap pieces he previously coated so I could find an orange that went well with the Columbia Blue Diamond I chose.Did you select your powder with your coating guy and he then ordered what you needed? Estimated the amount and all?
Thanks for confirming! This is what I was thinking but wasn’t positive. I think I got a pair located for $75.Good thing with a non-LNF build is you can use any non-LNF knuckles including base model, so they're pretty easy to come by in junkyards as well if it comes to that.
