Thanks and will do. I’m missing that piece.Needs to look like this:
Check the length on both ends of the shifter cables, use the right bracket, and match to this photo.
I ordered the set from Fitment Industries, which listed the different Vors wheels showing 5x110. I also checked the Vors site and saw the same information - no 5x110 listed. Possibly receiving 5x114.3 was my first thought, but I double and triple checked the hole spacing on the wheels. They’re right at 110mm. The studs on the hubs measure a shorter distance at around 105mm.Are you sure those aren't 5x114.3? If they are, you could just get adapters.
Edit: the Vors TR4 product page only lists 3 sizes, and 5x110 isn't one of them. 99% sure those are 5x114.3.
I don't think that is the right one either. It may be for the other manual transmission.This is the bracket that DF sent for the missing shifter bracket. It doesn’t look anything like the other pictures I’ve seen. I can’t make heads or tails of it. Assuming it is incorrect? Would it go with non SS / base manuals?
They are backwads. the cable mount is on the top and the hydraulic fitting is on the bottom.Working on the emergency brake system in preparation of first test drive. Does the cable mount on the bottom of the caliper assembly, or do I have something backwards?
