Hello,
I'm about to take the front suspension out of my donor and I'm having trouble with the sway bar links. Cracking the 18mm bolts loose was the first trick but I got that done with an impact drill. But now, the bolts just turn inside the sway bar links. I've tried getting in behind them with a pair of needle nose pliers to hold them tight, but that did not work.
Any thoughts/suggestions? Thank you!
