Do I need these sensors and valves? 2005 SS/SC
The one you are holding is to the evap. The one next to it is boost control solenoid. It’s needed and goes to the the boost actuator on the supercharger.
The EVAP that is in your hand, no, you don’t need to keep it. The other one for the boost solenoid, yes, keep it.
Whidbey Goblin
I’m under the impression I have to leave the a/c pump. Do I need to plug these holes? Do I leave the wires plugged into it?
You have to have it so the belt works properly, but you can gut the compressor to save weight. You can eliminate the plug and wiring.
