Most idler pulleys are mounted with 1 bolt. One year so far, no issues.Have you been running this motor for a while with the AC compressor this way? I’m a little concerned it has lost strength by only having two bolts hold it.
Are you running a stock or smaller pulley on your supercharger?I ran my first goblin over 7k miles with the gutted AC compressor with only 2 bolt. Zero issues.
Nuker-
I was running the ZZP stage 3 with 2.8" pulley.Are you running a stock or smaller pulley on your supercharger?
OK, thanks for the info Lonny. I will probably just solder them in but I’ll let you know for sure before you receive the harnesses. I’ll be shipping my harnesses to you today.That is odd, I can install a standard fuel pump connector on your wiring harness and you can get a new fuel pump or a used one from a salvage yard. Or I can leave the wires open and you can solder them directly to your existing pump harness.
Purple
Tan
Gray
Black
Water driver was able to reuse the existing plug on his old fuel pump. I’m thinking of doing the same. You wired in the standard plug when you did my harness and I opened it up a little bit. I see black gray tan purple. Which is which though? I know coming out of my pump I have power, ground, and two for fuel level sensor. I assume the black and gray are power, the purple and tan are fuel level sensor. Which is power, which is ground? Is the fuel level sensor polarity sensitive?OK, thanks for the info Lonny. I will probably just solder them in but I’ll let you know for sure before you receive the harnesses. I’ll be shipping my harnesses to you today.
Thank you. After opening stuff up and looking close I was able to figure it out. I appreciate your advice on reusing the plug, it worked great. My first start went well.Best photo I could get, sorry.
Pump harness plug:
Harness side plug:
Yeah, you gottat have a first start video- It's a right of passage. LolFirst start video?
I will post it, it took awhile to get fuel in the system so it’s kinda long.Yeah, you gottat have a first start video- It's a right of passage. Lol
can’t for the life of me figure out how to post a video on here.Yeah, you gottat have a first start video- It's a right of passage. Lol
