Donor with Aftermarket Supercharger
KingChuck24
Hello everyone,
I recently acquired a donor with an aftermarket zzp supercharger on it. I am not sure if this will fit with the goblin and was looking for some info.
Thanks for any help!
Pictures would help. The stock supercharger fits on my 2.0L engine... Do you have the 2.2L engine?
The ZZP kits are designed to fit under the hood of a Cobalt, so you probably are fine in a Goblin.
jirwin
The ZZP supercharger kit for a 2.2L fits, but I had to do a slight bit of modification. The alternator bolts had to be switched to hex head instead of allen head for clearance. I also had to maintain the AC compressor for proper belt routing (ZZP kit assumes you have AC). I gutted the AC compressor so its just a pulley now. Check my build thread for more info on that.
