Vwsaabvt
you can see a little more of it in the new VW project blogOooooo, that looks like a new space!....keeping secrets again, DF?
I believe they has some space up in Mountain View.you can see a little more of it in the new VW project blog
It being a tube maybe the rack goes in the housing only from one side? Feel free to destroy one and find out. I'm curious too but mine are working this way so not inclined to dig further.I was sure it was as designed, just not be able to see inside to understand the internals it seemed odd.
I found it easiest to shine a light through the hole you're supposed to put the tool through and then go through the back of the wheel. Worked for me this last time, quite well.Just now disassembled steering wheel. I always seem to have a hard time popping Air Bag out
I noticed that on mine as well. Something I too will have to do.Although the mounting holes for steering rack were spot on, as I had to do with Goblin 1.0 I had to enlarge the clearance hole that Steering Shaft goes through. I would say between 7 & 11 O’clock? would have been cleaner if had done that before mounting the panel.
And the lower shaft can only go on one way because the bolt needs to go thru the clearance radius on the shaft.
What's a good price on these? I've been thinking about getting some for a while now, but not sure what the 'buy price' is on these.How nice is this going to make working on the Goblin going forward.
Little extra height than jack stands.
