Scott Geyer
Is it an option to be able to run 85 and then switch to premium gas or is it one or the other only?
I don't believe the LSJ (P12) or LNF (E69) PCM can do this. The E37 and E67 (2.4 and later 2.2, not respectively) can be pinned for a flex fuel sensor, but I've not seen it confirmed that they can do flex fuel switching in Cobalt applications. Most aftermarket ECUs can do it, though.You just need a flex fuel controller that taps into the canbus and then have the tune updated for it, it will automagically adjust injector and timing. Worked amazing on my old Miata
Not sure I would call it dumb. It just depends on what the ECM was shared with and whether there was a Business or Regulatory case for having E85 available. Then it's just luck to have it available on a vehicle that didn't come with it. The availability on LS cars is probably due to the shared ECM with trucks. And even then, it can be hit or miss on what can be done. The OEMs don't have the "tuners" in mind while putting this stuff together.I looked into this, and you are 100% correct, so dumb being that LS ECU’s from the 90’s support it…
Sorry for the back and forthThanks guys. Appreciate your feedback.
