jamesm
We've all been there, however, it would be good to share the solution so others that find this thread can benefit from that knowledge.I figured out my engine issue but it was way too simple and somewhat embarrassing
Sames! I’d like to hear others follies to help make mine seem lesser.On no, not sharing solutions isn’t allowed.
I had this issue and just pulled on the clutch pedal a little bit to bend the bracket and create some clearance from the shaft.During my short initial trip through the neighborhood, I noticed the steering shaft u-joint hits the clutch pedal when it’s fully pressed. Is this normal and if so is it a live with it issue or is there an easy fix?
It barely cleared the bulkhead and I replaced the collapsible shaft with a new one. I'll try a combination of your suggestions and Brett's before trimming.Most will hit the front bulkhead (formerly known as firewall), so you just trim a little bit of it.
is that shaft locked up or did it move freely? If it’s bound up it may be putting pressures where they shouldn’t be and it could hit the pedal. Plus you can loosen the pedal and try to move it over a tad, and do the same with the steering column. We are only talking fractions of an inch, but it may be just enough wiggle room for it to clear. After that you could possibly trim the pedal, but that would be last resort.
My build had the same interference with the steering shaft and clutch. I don't like angled pedals so I trimmed the plastic on the clutch pedal that hit the steering shaft. Once it was trimmed enough to clear, my pedal is straight. I then JB Welded a thick steel washer onto the clutch to still get good contact on the electrical switch at the bottom of the throw.During my short initial trip through the neighborhood, I noticed the steering shaft u-joint hits the clutch pedal when it’s fully pressed. Is this normal and if so is it a live with it issue or is there an easy fix?
It’s on my wish list.Such a great-looking ride... you really need a quick-disconnect wheel though!!
I have lots to do while waiting. I do need to clean it up and get the metal painted once this cold spell passes. First night of freezing temps of the season...I am NOT ready for this.Might as well do your e-brake while you wait for the inspector. It takes maybe an hour to do, super easy compared to actually building this beast.
I hear that. I drove the Goblin to work today in 36-degree temps. It was fine ... just have to dress right.I have lots to do while waiting. I do need to clean it up and get the metal painted once this cold spell passes. First night of freezing temps of the season...I am NOT ready for this.
Sorry, I had my latch bracket installed before the grill brackets so it didn't cross my mind to mention the kinda share the same space.So Pete and RePete showed up in the shop today and I’ll share in hopes of saving someone else a little trouble. If you choose to add a grille and choose to use some form of bracket like this, remember to leave clearance for the hood mounting plate since it mounts inside of the lip at the bottom and not outside. If you forget, you will either have to remove your bracket or cut them down like I had too.
