Jareth
Wanted to add to the following post from Lonny:
http://dfkitcar.com/forum/index.php?threads/flat-towing-the-goblin-any-guides.960/post-19106
I found the following info online that I wanted to add to the discussion and debate?
"you should never flat tow one. in an automatic the pump is driven directly off the torque converter. when the engine isn't running the pump will not turn. what happens when you flat tow it is there is no lube flow to the gear train and it will burn the bushings and bearings up and eventually do major damage to the planetary gear sets. the only way you can properly flat tow and automatic is with the engine running and tranny in neutral. this allows the pump to turn and you will have the normal lube flow."
I then also found a post that stated the following.
"With the change to the Hydra-Matic 4T45-E as the optional transmission, all Ions now can be flat-towed – pulled behind another vehicle without the need for a special dolly – making Ion an ideal choice for RV owners.
Since the Cobalt uses the same transmissions as the Ions there should be no reason you cannot flat-tow a Cobalt as well. The document didn't specify whether it mattered or not if you have limited slip, so that should be safe as well."
