I was wondering the same thing. If you can do a bit of fabricating, it should work fine.I'm getting close to placing my order, picking up the donor tomorrow, and need to know, do I need one if these? If heat is a problem, then it will be a big problem in Vegas.
So, if you are running a hood, why can't the bulkhead/forward firewall run up to the hood and seal at the hood/firewall seam instead of using the footwell cover? Is there something I don't understand?
