I see you have a bike problem (not problem) tooMaking progress on day two of the teardown.
sweet
good on the progress And the engine.
Yes, a 17 Ultra Classic, a 19 Heritage Softail, and the wife's Suzuki C-90 and her Crotch Rocket, Honda F4i. Luckily there is room in the other garage for our trucks. Your project is looking good and I see you have a few scoots of your own !!!I see you have a bike problem (not problem) too
sweet
Maybe a few.Yes, a 17 Ultra Classic, a 19 Heritage Softail, and the wife's Suzuki C-90 and her Crotch Rocket, Honda F4i. Luckily there is room in the other garage for our trucks. Your project is looking good and I see you have a few scoots of your own !!!
Sounds like a plan. I have a 26HP Kubota with a bucket on the front and will probably do the same thing.It's a good thing they put the allen head on it. I've come across others that didn't and you have a heck of a time getting the nut off when they start to spin. You won't really need the sway bar links.
We were fortunate enough to have a tractor with a loader and we lowered the car and all onto a dolly and the lifted the car off of the engine/cradle. Made quick and easy work to separate the two.
Looks like you don't have much more to go. The dash is a lot of fun to get out if you don't have help.
you might want to support your axles to avoid damaging the articulating joint.End of the day pictures (25 July, 2020). Moving right along.
Thanks, will do that right now.you might want to support your axles to avoid damaging the articulating joint.
Put the old brake lines to good use, supporting the Axle's.you might want to support your axles to avoid damaging the articulating joint.
They may not be as good as a lift, but they sure do come in handySounds like a plan. I have a 26HP Kubota with a bucket on the front and will probably do the same thing.
and those of us without a John Deere just call that cheating...........They may not be as good as a lift, but they sure do come in handyView attachment 15721View attachment 15722
I think the 4200 is also a 26HP tractor so my Kubota should be fine. May need to put on my bush-hog for some counterweight. My bucket is good for 1,800 pounds.They may not be as good as a lift, but they sure do come in handyView attachment 15721View attachment 15722
Two Goblins ....... hummmmm? Will take a look on EBAY. Thanks !!!eBay has some new crate engines (they're turbos mostly if i recall correctly) but I'm sure they have non turbo models too. You could always buy a 2nd donor and just sell everything else or build a second goblin!
