Front and Rear Bumpers - Pictures, Ideas, Concepts, Drawings
Place to come for Front and Rear bumpers for the Goblin.
For those that need to have a front and rear bumper. Or even builders that want to add one to their Goblin. Some states require Front and Rear bumpers.
If you have a Front or Rear bumper please post it here. Also please add details: Dimensions, Drawings, Materials, how it is mounted, any and all info.
BAR-AIR
The back bumper is actually a bumper protector from a KIA Sportage that has been shortened in the middle. The mounting brackets is 1/4" steel that mounts between the frame and the engine cradle. It does have slots to adjust the bumper. It does meet the 16" height for the ground requirements.
The front bumper is the rear bumper protector from a Toyota RAV4 the Kia's sat way to tall to use in the front. The nice thing with the RAV4 only the upper tube had to be shortened. Custom bracket using the upper and lower control arm bolts eventually incorporate the tow bar into that bracket (just for short distance tows). Again it just meets the 16" height requirement you could also raise the front end higher with the springs if necessary for inspection.
