Waterdriver
There's always this option?!
I want it all! Face distorting levels of grip.
Looks like higher drag than downforce if it is going at any speed above 30 MPH. But dang that IS A LOT OF WANG! Edit: and looking closely there appears to be rubber skirt under the frame too.There's always this option?!
The addition of front downforce is what is needed on the Goblin. Good Luck!Don't know what the downforce will be, but if it doesn't seem to add anything I can always move it to the back.
I also bought the same front wing but my mounts are spaced at 18” for some reason. Did you request 16 1/2? I like your mounting setup but it looks like it wouldn’t work for 18”. Cool to hear you were able to use aluminum. I just figured aluminum would be too flimsy. Also good to hear you can truly feel the difference.Just upgraded the front wing mounts to 2” x 3/16” aluminum angle. Much better. I can stand on it and bounce. The suspension will compress before the mount flexes.
I love the feel of the steering now. I can hear the front tires “singing” at speed with the added downforce.
I did ask for the mounts to be welded at that measurement. I'm sure you can make 18" work.Did you request 16 1/2?
Not with the DF body. From the looks and shape of the DF nose, fitting tightly around the radiator, I dont think you could modify it and have it still look good with my front wing mount.Does it fit with the body on?
C.A.D. - cardboard aided design?Not with the DF body. From the looks and shape of the DF nose, fitting tightly around the radiator, I dont think you could modify it and have it still look good with my front wing mount.
I had designed the front wing mount to work with the body/nose that I'm working on. Currently in C.A.D.
I knew someone was going pick up on that.C.A.D. - cardboard aided design?
