Fuel pump ?
RETNAVY
Hello group I got this cel twice now I am assuming fuelpump and or filter , car is stock tuned with a k04 plan on converting to e85 so it looks like the stars aligned .
also need input of an upgrades fan for better cooling
Need to check fuel pressure and fuel trims and go from there.
What makes you think you need better cooling?
I would check for air pocket in the cooling system or a non-function fan if the temps when this happened was under 100 degrees. There just hasn't been many if any reports of overheating with the stock setup.
This ^^
we run autocross in dead of summer (100°+) and none of us have overheated. At worst we can overheat intake temps, but not ECT. I run a spal fan on my rads, but I know the others here are stock DF fans.
