Hrmmm maybe I do have it right, dang-it now I have to check when I get home from work.The pre cat o2 and post cat o2 have different connectors.
pre cat o2 is female (male on engine harness)
post cat o2 is male (female on engine harness)
Check for continuity on pins 1 and 2 of your OBDII port. If there’s continuity, CONGRATS! You made the same mistake as the vast majority of us SS/SC donors (including myself) and tied the communication pin on the OBDII port to the GMLAN. Pin 2 on the OBDII port should go to PCM C1 pin 16
Bill's Street/Track Goblin - 2007 SS/SC - Chassis #204
It bolts down to your subframe, and holds your rear wheels straight.dfkitcar.com
Maybe this has been discussed previously (I know I've seen it in other threads), but did your inspector waive Michigan's glass windshield and wiper requirement?Well today is a day of mixed emotions.
Start with the bad:
First fire up and she cranked right over!!! I was shocked! I plugged in the fuel pump and primed it then the car struggled to fire up but eventually took off. Then it died….. found a ground I missed and tried again. Fired up and ran rough, so I gave it a tap on the throttle and the revs went up and seemed smooth. It just has a lumpy idle. Help?
Not sure how to post a video to show.
Secondly I think I made the rookie mistake and crossed some wires because I am not getting any readings from the OBD port. I know @Ross probably knows what mistake I made. I have been trying to do some research on it.
Now for the good:
Once my total comes in I will be able to go get my plate
Let it go man……let it go.Go Michigan!
That still has a burr under my saddle. One of the few things Texas made hard...
Texas Revoking Titles (and how you can help)
Hypothetical question: The owner of a Goblin who has successfully titled said Goblin in another state moves to Texas and brings said Goblin with him. Shortly after his arrival he stops by his local DMV office (with his OK, NM, CO or wherever title in hand) to apply for a TX title. What kind of...dfkitcar.com
For those of us unfamiliar with MI files/forms, does that mean your titled, insured and now tagged?Wheewwwww
yes to all the above, it’s my temp tag until I get my plateFor those of us unfamiliar with MI files/forms, does that mean your titled, insured and now tagged?
