Ghostknife
This is all I’m pulling with the code reader.
The car was tuned by zzp so I don’t know if that has anything to do with it. The donor was tuned when I bought it. Other than that it’s all I know. Maybe it’s the program I’m using??? OBDlink app and OBDlink MX for the dongleWeird. You are missing cat and o2 codes, so there has to be more or they are being ignored by hp tuners or something.
Awesome, thank you!That’s correct.
Yup that’s the plan.Easier yet. Drill a hole in a valve stem cap, the size of a carb cleaner straw. Remove valve core. Insert straw into cap, cap on valve stem and valve stem onto injector. Add 12v to connector and spray carb cleaner.
View attachment 34029View attachment 34030
Old mechanic's 'stethoscope' trick; use a long screwdriver, put the tip on the injectors (or any other operating part) and put your ear against the end of the handle. You will be able to hear if it's operating/making noise.You can use a mechanics stethoscope to try and listen to the injector.
Quick tutorial on testing injectors. How to Test Fuel Injectors (with Pictures) - wikiHow
I would just swap it to a different location to start.
