Tim Moland
I noticed that my drivers side headlight was not working. I figured the bulb burned out, so I ordered some high powered led replacement bulbs, cause let's face it, the stock ones are pretty dim. After removing the old headlight, I found that the headlight connector was melted and smelled horrible like burnt electrical wires. So I decided to look at the passenger side headlight also. Not quite the same thing, but you can tell it has been hot and blackened the connector. I did a test with the Voltmeter, and everything works like it should. I'm getting the correct 12 volts in the correct spots for low beam and high beam. So it's not an electrical problem. Is it just heat from the headlight? I have noticed that when they are on, the outside bucket gets very hot. I figured it was normal. The new bulbs I got have cooling fins on them, but they barely fit in the old buckets. I was thinking about cutting what is left of the old connector off and putting single female blade terminals on the wires instead of a bulky connector for all three wires. That way I have more room internally for the new bulb. Any suggestions?
