@Mayor West sent me some 3d-printed tabs/brackets. I was just looking for them in the 3d-print thread but don't see them in there anymore. Perhaps he'll see this and provide the .stl files. I swore they were in that thread ... I may be blind.@Ark :D i got nearly identical buckets and lights to upgrade mine. How did you mount the bucket to the shock tower?
They're there. The first post has a link to his original post in the tech section where he attached the .stl files are attached.@Mayor West sent me some 3d-printed tabs/brackets. I was just looking for them in the 3d-print thread but don't see them in there anymore. Perhaps he'll see this and provide the .stl files. I swore they were in that thread ... I may be blind.
Second this. The low beams are actually really good. The high beams don't add a ton of extra light but the lows are good enough it that it doesn't really bother me.I love mine. Amazon cheapies, but they work great and the price was right.
Headlights
Matching buckets
There's 3D-printed mounting rings and tabs that @Mayor West designed that are needed, as well. I think they're in the 3D-print thread.
Thank you! I totally forgot about that thread and I even commented on it... I printed a pair out of ABS. I did have to run a 3/8" bit but they fit really well.They're there. The first post has a link to his original post in the tech section where he attached the .stl files are attached.
5.75" Headlights under 100$ with Highs/Lows, DRLs, & Turn Signals
I have finally finished my headlights, I ended up buying a metal housing from Amazon to go along with my cheap eBay headlights, but the included setting ring didn't even fit its own product so I successfully 3D printed a correctly sized one that works well. Figured some others may be...dfkitcar.com
Where did you find the brackets for those?I will be going with LUMEN 4x6 LED headlights on mine with an integrated turn signal HALO for maximum visibility on the streets and some cheapo mounting brackets (if the brackets are trash I might make my own better version) I do love the look of rectangular headlights here.
$10 on ebayWhere did you find the brackets for those?
