cdover2005
First attempt starting the Goblin today and unfortunately it won't start. Here is what I was able to diagnose so far.
- The Pwr/Train Relay is buzzing when the ignition is in the On position. Check Engine light pulses in sync with the buzz.
- Checked grounds and I have continuity at all grounds and they are all connected. (11.5 VDC at lugs). I went through the harness and relocated 2 that I thought were the problem.
- Fuel pump does not prime.
- Throttle Blade does not move with the gas pedal.
- No cranking when ignition is in Start position.
- No communication with my OBDII reader when plugged in.
I searched the thread for similar issues and most seem ground related but this one has me baffled.
