KingChuck24
So I have been attempting to assemble the front upper and lower control arms. I have had some issues with tapping out the threads mostly due to small little pebbles or little debris getting stuck in the thread.
One of the rod ends I put into the control arm also got stuck in a very similar way but through a lot of brute force I was able to remove it:
This is how messed up the thread was when I pulled it out.
So basically I put the rod end into the threads and tightened it down and then I would feel some force against me. I would start to pull it out then it would get harder and harder, this caused it to get stuck.
I have accidently done this again and I have no idea how to remove this other stuck one:
I have put it into my vice and attempted to loosen it but it just keeps getting tighter and tighter, I accidently ruined the powder coat on the control arm which is also very unfortunate:
Bad photo but it is all scuffed.
I don't know if anyone else has experinced this. If so what did you do. I am considering grinding off the top and drilling out the bolt, my only concern is I will not drill straight and completely destroy the threads of the control arm.
My current thinking is, maybe try with multiple people to force it out, I don't think this will work but maybe worth a shot, next I would probably attempt to drill. If all else fails I may need to order another control arm from DF and get it coated.
Edit: I could also maybe drop it off at a machine shop or some place that could try and get it out for me.
