I have a 2008 SS donor and my only fuel filter is the one inside the tank that attaches to the fuel pump, I ditched the OEM hose and replaced it with rubber fuel line, but I re-used the OEM fuel connectors - just transferred them over to the rubber fuel hose with hose clamps. Made it much easier to route the fuel line. add another inline fuel filter if you want its your life lol!
I ran the hose from the top of the fuel pump to the fitting on the intake manifold.
EDIT: I believe the stock hose will fit you just have to persuade it to reach both connectors
Turbo cars only have 1 hose and no inline filter
This is connected to the evap system which isnt being used. so you dont need that hose. I created a small blank off plate to cover over where the evap solenoid is. most people just leave the solenoid in there to plug the hole - unplug the blue/red electrical connector.
