Two data wires, high and low (tan & tan/blk). They daisy chain everything together in series so certain modules know what other modules are doing. At the front of the bus, you have the ECM; at the back of the bus you have the Power Steering Module. Each of those have a 120 ohm resister to provide voltage drop and signify bus termination.
You can see there are different modules on the bus, depending on what options the car came with. You can see that the TCM, VCIM, and EBCM are bypassed if the car did not come with these modules.
For the Goblin, all we need to worry about is that these two bus wires run continuously from the ECM. We remove the brake control module and VCIM, so they will bypass those. Where they previously entered those modules, we cut the harness and patch those two wires to the exiting wires of the module similarly as it shows in the diagram.
What is most important is to ensure the bus remains intact, otherwise the modules will not communicate with each other.
