Forceofaqua
I would assume this is a simple thing to do, but my multi meter readings are simply not changing. I am testing resistance between the two prongs with light and no light and nothing changes. Can someone do this test to show me what the sensor should be reading, or tell me how to test it?
The issue I'm running into is that none of my running lights are working, and I've tested continuity across all brown wires and the fuse box. The fuse is also not blown. The sensor is the last piece to test, and its brand new out of the box.
Secondary question, is there an easy way to bypass the sensor to force the daytime running lights on? I'd like to test if all the wiring and the dash light up.
