Nope. Probably should.Lonny: When you add the Quaife LSD to a transmission at the factory, do you alter the plate and stamp it in some way?
If you have both axles out and look through the axle holes you can see a difference.View attachment 14263
The image above is not a limited slip differential.
This one is a limited slip differential.
From your pic and Lonny's post pic, if I rrad it right, you do have an LSD. Otherwise you'd see a shaft blocking your view through the transaxle.I know I'm bringing and old thread back from the dead but thanks for the info Lonny. I was bummed because my cars seller said it was a LSD but after I bought it I didn't have the G85 trunk code or tag on the trans. According to your pics looks like I have an LSD F35. View attachment 30350
