Mayor West
I noticed there wasn't a straight up how-to on the VXDIAG Tech2 tool, so I wanted to make a write up so no one else got confused on the installation. I hope this helps.
Those of you who have potentiometers for pedal sensors will need to do a clutch-relearn should you replace that sensor. That's what I needed it for. This is supposed to do just about everything a Tech2 can do, but not cost a billion doll hairs.
For just over 100$ with taxes, I bought this VXDIAG from Amazon. It came with the tool and a white disc with a bunch of files/folders on it.
It has instructions, but all of the files on the disk are useless, so you have to download updated versions of them elsewhere. vxdiagshop.com has them as well as allscanner.com has the latest VxManager. I could not get it to work without updating every piece. It's all free so it was mostly just frustrating because the online instructions are crap.
Requirements:
The order of installation is important.
1) Install VMWare-Player 6.0 (32bit version) but do not open it.
* I'm not 100% sure this is necessary, but various other installation write-ups say to use it. I haven't tried without it.
2) Install Tech2Win
3) Install GSD2
4) Install VX Manager
5) Plug In Device, let it load drivers (it may take a while) and make sure it loads in to USB Serial Port COM4 with Device Manager after the driver finding part is done.
6) Run VxManager, update your devices firmware and licenses one after another.
7) Run Tech2Win and select "NORTH AMERICAN"
8) You should be prompted to select a device, select the top one (without a 2 in it)
9) If all went well, you should then be prompted to select another device, it should say your USB device. If this shows up, your MDI Candi module is all good.
When it's ll connected, Tech2 prompts you for a Product Line Code after selecting a few vehicle options. I'm not sure about every year, but the Product Line for my 09 SS/TC was "A" You may have to test other letters or see if one corresponds do your VIN #'s 3rd or 4th letter character.
Requirements:
- VXDIAG VCX Nano for GDS2 (such as the one linked above)
- 32 bit non-VM Computer (Apparently these won't work on VMs, although I have not tried that)
- VMWarePlayer 6 (32bit), Tech2Win, GDS2, VXManager software's latest versions all available here (go to GM section down the page)
2) Install Tech2Win
3) Install GSD2
Select Passthru & GM-GDS when promoted
