Quoted for truth. You want these from ebay - pry out the old fastener and push in the new (I did not grind off the welded stock df plate and rivet on the new one - just take them apart)I just replaced mine with Dzus with another Dzus that uses an allen wrench.
This is the primary reason. Unless you buy the special tool for $27 and still end up with this over time. The allen doesn't easily strip out. And besides you need tools to do the other two bolts on the dash. Once the car is complete and the bugs worked out, we have only taken it off once this yea, so having to use a tool is no inconvenience. And it's a lot easier to modify than to redesign the whole thing.So, for those of us who have the DF supplied ones... how is an allen head any better/easier than a slotted head? Both need a tool. Wouldn't something that's big enough for you to wrap your meat hooks around work best? I like the idea of that button push thing but the pictures are super blurry and I can't tell whats going on.
And the stubby is not really even the right tool but it's the only thing you have that's close. I even modified a sacrificial stubby to make it fit better but still not good enough to keep it from buggering it up.You have to have a stubby flat head which is always that tool that's impossible to find. So by the time you find it you're all crabby and then you go to turn the fastener and end up stripping it because they might as well be made of crayons. The allen-head experience is not like that. DF should use these as default
Elaborate? On the top or bottom?What size quick-latch did you guys use?
For fear of sounding like an a55, there are two ways to hold an Allen wrench. One direction for speed and the other for torque (assuming using the standard Allen key). A quarter turn using the stubby side of the Allen with properly adjusted Dzus fasteners is a breeze with two fingers.Wouldn't something that's big enough for you to wrap your meat hooks around work best?
The head size on the minis is .875 to 1.5, I'm not near the car currently to measure.Elaborate? On the top or bottom?
