It uses the stock intercooler on a Cobalt, but on the Goblin you would use all the same intercooler components as used with the SC donors. So it doesn't matter what shape your donor's intercooler is in.Unfortunately, my stock heat exchanger is pretty busted up.
If you are planning on changing the intercooler setup, don't go with the entry-level turbo swap kit. It is designed to be used with the LSJ intake manifold (reads: laminova core setup) and you're just buying parts you will be getting rid of if you plan on using a different intercooler setup.Yes, the Laminova cores is the stock, limited intercooler.
If you want to upgrade, I would shop at frozenboost.com.
I think this is the intercooler DF supplies for the turbo cars, with this heat exchanger. (You already have this from DF)
Frozen boost also sells A2A intercoolers, charge pipes, etc.
Well buddy its possibly your lucky day. I just happened to stumble upon this post and I just started collecting my A2W setup. I have converted to A2A because I apparently like to spend money yes its more costly. The A2W is New Setup with about 30 miles on it. From my chat history you can see I was fighting hot air on my supercharged setup. This will mount upper behind head. This setup is warmer on idle but once you are moving it cools much faster as I was data logging with HP Tuners I think it was worth the upgrade for sure. I also would include a Phenolic Spacer for the cost I mention that below. Overall its an easy setup just a little measuring and thread tapping. Also removes the tubes down the center and front heatsoaking heat exchanger.Thanks @Ross - I appreciate the detailed overview here.
I spoke with Ryan at ZZP on Friday last week and have discovered that the entry level turbo kit, which is what I have, is intended to integrate with the stock A2W cooling system, which I was unaware of (silly me, still learning about forced induction). Unfortunately, my stock heat exchanger is pretty busted up. What are the best after market options for this?
Also, as far as I can understand (but please correct me if I'm wrong), the Laminova cores inside of the intake manifold are what serve as the intercooler. Is this correct? If so, it seems like a very limited design, especially when moving to a turbo setup. Are there any good after market options for a better intake/intercooler assembly?
Which intake manifold is this? Not sure I've seen this beforeIf you are planning on changing the intercooler setup, don't go with the entry-level turbo swap kit. It is designed to be used with the LSJ intake manifold (reads: laminova core setup) and you're just buying parts you will be getting rid of if you plan on using a different intercooler setup.
Using the DF A2W intercooler for turbo cars, you will be using a different intake manifold, so make sure to plan this all out before buying parts.
Just wanted to say that I really appreciate your feedback here. I’m finishing up my build with stock LSJ, but future plan is s252/s257 but staying a2w. My plan was to use the df h/e upfront with a fan, but also add a second h/e like what you did, hoping it was low profile enough that I’d still have rearview visibility. Get all this cooling in place (dual pass, phenolic spacer, zzp intercooler pump) and run a year or two with the m62, but later turbo swap. Leaning toward the OTTP intake mani (wondering if I can run that with the phenolic spacer just because), but add the a2w intercooler like df uses for the lnf kits.Well buddy its possibly your lucky day. I just happened to stumble upon this post and I just started collecting my A2W setup. I have converted to A2A because I apparently like to spend money yes its more costly. The A2W is New Setup with about 30 miles on it. From my chat history you can see I was fighting hot air on my supercharged setup. This will mount upper behind head. This setup is warmer on idle but once you are moving it cools much faster as I was data logging with HP Tuners I think it was worth the upgrade for sure. I also would include a Phenolic Spacer for the cost I mention that below. Overall its an easy setup just a little measuring and thread tapping. Also removes the tubes down the center and front heatsoaking heat exchanger.
Original Order: $332.73
1 x Remote Radiator Inline Filler Cap - 3/4" (WAT001064) = $26.99
10 x 0.75" Reinforced Silicone Heater Hose, Black (per foot) (WAT000642) = $44.90
1 x Water to Air Intercooler Radiator - 26x7x2 (Type 118) (WAT001063) = $169.99
1x Earls AT991104ERL = 14.95
350-8165 Heater Hose Fitting 90° Angle Fitting - $75.90
Spray Painted Eastwood Satin Black Radiator Paint
Sell For: $280 buyer pays shipping
You will want Tube Clamps x4 - AAF-ALL10456
Square Bar https://www.ebay.com/itm/384275871392. Can also buy from Lowes / Home Depot.
4x swivel bolt thingys forgot name (see pic)
I also have a dualpass and intercooler pump. The intercooler pump has probably 200 miles on it. Make me an offer if you want.
Lastly I have a new ZZP Phenolic Spacer in the package. This was never installed but I heard it makes a huge improvement I will let this go for $70 if you decide to order the heat exchanger.
LSJ Phenolic Intake Spacer
A hot engine heats up the air that is flowing through your intake. The engine is aluminum, as is the intake and they conduct heat very well. Your 180 deg engine adds unwanted heat to the LIM which houses the intercooler. That is why you need to upgrade with our ZZP LSJ phenolic spacer. A cooler...zzperformance.com
View attachment 38571View attachment 38572View attachment 38573View attachment 38574
I had some visibility issues in the rear, but I don’t really look behind me much. I had some invisibility issues in the rear, but I don’t really look behind me much. The one potential issue one could come into with the two heat exchanger set up is the pump not having enough pressure to feed the upper heat exchanger. I guess this would be easy to test if you were planning to keep the upper one anyway.Just wanted to say that I really appreciate your feedback here. I’m finishing up my build with stock LSJ, but future plan is s252/s257 but staying a2w. My plan was to use the df h/e upfront with a fan, but also add a second h/e like what you did, hoping it was low profile enough that I’d still have rearview visibility. Get all this cooling in place (dual pass, phenolic spacer, zzp intercooler pump) and run a year or two with the m62, but later turbo swap. Leaning toward the OTTP intake mani (wondering if I can run that with the phenolic spacer just because), but add the a2w intercooler like df uses for the lnf kits.
With that second h/e on the rear bars, did you have any rearview visibility between it and the engine?
You need an NA intake. ZZP includes a Saab intake manifold in their LSJ Complete Turbo swap kit. OTTP also offers an LSJ Turbo intake manifold.I really appreciate everyone's input on this
@Sluggonaut Sigh - yes this is the realization I've come to as well. I should have just gone with the S257 to begin with as I had originally planned. Chances are, I'll probably end up yanking the Z54 off and redoing the entire system with an air-to-air S257 setup, but I have the Z54 already, so I figure I should at least give it a shot before I scrap my plans and start redesigning everything.
I saw that Saab intake from ZZP...Do you know if that manifold still retains the ability to used those Laminova cores and a dual pass end plate? I know the whole point of the modified intake is A2A but I wonder if you could achieve even colder air with both in place. Who knows, maybe it would be so little of a gain that it wouldn't be worth it.You need an NA intake. ZZP includes a Saab intake manifold in their LSJ Complete Turbo swap kit. OTTP also offers an LSJ Turbo intake manifold.
For me it came down to cost - I had all the parts I needed. Trying to add the DF A2W setup was going to be over $1k to try to make it work versus the parts I had on hand that bolted right up. I'm running E85 so that may contribute to keeping things cool, but I've had no issues.
No, the NA intakes don't have laminova cores in them and the dual pass endplate is specific to the LSJ intake.I saw that Saab intake from ZZP...Do you know if that manifold still retains the ability to used those Laminova cores and a dual pass end plate? I know the whole point of the modified intake is A2A but I wonder if you could achieve even colder air with both in place. Who knows, maybe it would be so little of a gain that it wouldn't be worth it.
