I was trying to help another person out, I rebuilt mine already but he jacked up all the pieces on his including the intermediate shaft housing.If you already have the intermediate axle, all of the parts should be available to rebuild it. If I can dig up the link to the bearings I'll post it here.
Nuker-
Ahh gotcha sorry!I was trying to help another person out, I rebuilt mine already but he jacked up all the pieces on his including the intermediate shaft housing.
I suggested he check with Jefferey Reiland on Facebook
Oh no thank you for offering the helpAhh gotcha sorry!
nuker
Our second Goblin was a base manual that had a long passenger side axle. Without looking at you would never know it had a long axle.A Base model NA uses a one piece shaft on the passenger side. It directly connects the transmission output to the wheel hub. This axle is far weaker than the 2 piece axle used in the SS. But keep in mind this configuration also transmits torque 'steer' - in the FWD application - and I'm not certain how it would respond in the rear drive of the Goblin.
Thank you very muchThere is at least one on ebay right now for $65 +$25 s/h
Chevrolet Cobalt 2L Supercharged - Intermediate Shaft Half Shaft axles - 2007 | eBay
Would a base manual passenger side long axle fit on a Goblin that had the intermdiate driveshaft?Our second Goblin was a base manual that had a long passenger side axle. Without looking at you would never know it had a long axle.
Even when Adam autocrossed his base manual Cobalt it did not have any odd steering tendencies. It did squeal those skinny stock tires through every turn though.
I showed the guy the one on ebay but it would take to long to arrive for him.Would a base manual passenger side long axle fit on a Goblin that had the intermdiate driveshaft?
Yes they are going to be like goldOh. Good to know. I bought it.
I think the transmission side of the F23 and F35 axles are different. If you could put the passenger side F35 stub on the long base manual trans axle then it would probably work.Would a base manual passenger side long axle fit on a Goblin that had the intermdiate driveshaft?
Jefferey Neilson REILAND has one for 86 dollars shippedOh. Good to know. I bought it.
