The first one is correct.I don’t suspect that it is critical but witch is correct for placement of the foam spacer on the brake shaft, the two DF videos have it different?
I think this first one Is correct?
I tapped the hole to take a different thread because I couldn’t find screws that fit. I know some others have thru drilled the hole and minted it that way.Does anyone know what thread hardware is used to mount the ignition to the frame, the video indicates to use small donor hardware? I don't seem to have anything small enough and when I took the ignition unit to Ace Hardware and nothing fit?
Those should be for the 3 screws to attach the steering wheel to the spline adapter.I couldn’t find any videos so it took a little bit, but I think I figured out how the pieces of the steering went together.
Let me know if you see anything wrong? Other than needing to install the self-canceling piece.
I had these three 5/16-18 x 5/8 button head cap screws left over? What are they for?
