Don't want to clutter up the LNF thread too much. And want document the events going forward here in my build log.
A little background. Engine has 86k total - about 4k in the Goblin.
All stock except for a tune upping the boost to 25 psi. This has probably exacerbated any issues.
Smoke in the exhaust has been noticeable for a while (10 months) but has slowly been getting worse. Smoke in the exhaust cleared up when I bypassed the PCV temporarily and vented to atmosphere rather than dumping back into the intake. The video shows there is continuous bypass from the crank case.
A new turbo installed recently seemed to actually make the smoking issue worse.
Quite a bit of exhaust from the oil fill cap when open, too. Although, I am not sure what exactly is a good baseline here. See video.
Here is my compression data:
cyl 1 - 140
cy 2 - 115
cyl 3 - 135
cyl 4 - 75
Not good at all.
Spark plugs actually looked fairly clean. See pic.
Did the colored dye test to check for exhaust intrusion into the coolant system - failed head gasket or cracked block. No color change of the dye. All good there.
Diagnosis at this point is blow by at the rings.
All you guys and gals who are smarter than me have any input / suggestions / questions here? Chime in, please.
https://youtube.com/shorts/5Ls0xZ-66L8?feature=share
https://youtube.com/shorts/sHXoW2A26PI?feature=share
cyl 1 - 140
cy 2 - 115
cyl 3 - 135
cyl 4 - 75
Not good at all.
