Waterdriver
No, it's been about a year and half and looks and feels like the day I installed it.Brake fluid doesn't sweat out of the fuel line?
Mine for sure did. Guess it depends on the exact type of hose.Brake fluid doesn't sweat out of the fuel line?
How long before it started weeping through?Mine for sure did. Guess it depends on the exact type of hose.
no clamps on the water lines?View attachment 12260
The tee is for making a fill port and air trap.
We have some new brackets that mount a coolant tank behind the passenger seat to use as a intercooler water tank instead of the tee. We haven't had a chance to use one yet. I will take a picture of it tomorrow.
There should be clamps in your kit. I don't know what the baggie number is though.no clamps on the water lines?
AN fittings aren't used, they just come with the HE box. Below could be the bag you are looking for, but only if the TC is the same as the SC:Hmmmmm. OK. Just sent Adam an email as well about this.
Do you have any pics? The fittings are not obvious as well. There are AN fittings, but no AN fitting hoses?
Where does the pump mount?
Where do es the "T" go?
edit - the fan does fit under the plenum. Could still use it right?
The wire harness has a drop for the heat exchanger fan?
thanks. Yes, I do have that hardware.AN fittings aren't used, they just come with the HE box. Below could be the bad you are looking for, but only the the TC is the same as the SC:
