not much change since it was right behind the seat back to begin with.How much does this increase passenger noise, if at all?
All temp differentials were between IAT1 (located in the MAF pre-intercooler I believe) and ambient. My OBD reader only displays one IAT. Not sure if the stage 1 GM 3 bar sensors still have a temp sensor to pick up the IAT2? Or maybe I need something more than the OBD reader I have?Are you talking about pre-turbo (IAT) or post intercooler (IAT2) temps? I have my intake outside the engine bay too and I still get a 10-15 degree temperature difference between IAT and IAT2.
I think I had to trim the 90 when I originally installed it.Oddly enough I was going to do this also, happy to see we can use the stock DF tubes! Thanks for documenting this.
When it comes to the tube mods, I'd imagine you had to cut the turbo tube (90 deg. one passing by the coilovers) shorter so it hugged the frame better -- anything else?
I’ll take those bad boys!When I had my friend fabricate my side scoops, I had him make a second set - just in case I wanted to modify them a little. I did not.
They do add functionality with a little added aesthetics as well.
So, if anyone is interested in a free set, first reply can have them for free. You pay shipping.
They are bare aluminum right now. You will need some 1.25" Adell clamps to mount them (if you prefer to copy my install).
Here are the details with pics:
Jason in Texas - ext. track - 09 SS/TC
Sunday night ice cream run to Sonic with the family - in each of their rides. Kind of got our own parade going..... :) Goblin on, friends!!dfkitcar.com
Or you can go the quick connect hose and end capOK. Don't be that guy. Like I was today.......
If you bought the same plug as me for the intercooler fill neck, heads up. Today while driving (hot, and a bumpy road), the plug dislodged and is now out on a road somewhere. I added a 1/2 ounce of coolant recently. Maybe I did not tighten the top. I like the simplicity of it, but maybe it did not have enough grip for the bumps, or maybe a little expansion due to heat. I will be reinstalling another one, but with a small zip-tie around the top of the rubber hose to ensure retention.
When my engine grows up and gets cleaned up, it dreams to be just like yours!!!!Or you can go the quick connect hose and end cap
