DCMoney
Bridgestone RE71R's. I experimented with tire pressures down to 14psi in the rear, and I would get a skating feeling out of the rear with that low of a pressure. Once the Bridgestone's are shot Ill probably switch to the Toyo's R888R's or something similar.Dc. What tires are you running? I’m a firm believer that anything over 200tw is an accident waiting to happen. I use the Toyo rzzr’s. And although I can get to slide and spin, it’s very controllable. I’m running 13psi rear and 11 front at autocross. The rear sway bar does help a good bit (Jason is not running one). In my test, I ran 48.3 with sway bar, 48.9 without and 48.4 with sway bar (with a small hiccup) in back to back to back runs. Without the rear sway bar I was “fighting” the car, with sway bar, the car is much stiffer and roll is a lot less.
when my new GoPro decided to work, I’ll post some videos here:
I'm running the non SS sway bar (18mm?), and agree the car has little to no body roll.
I'm running 125lb/in rears, with 400lb/in fronts.
Not sure my ride heights off the top of my head, but after going to the meet up in May, I know my front end seems lower than a lot of others.
