Hey, get the bumps out of the way now. Smoother sailing down the road! Congrats on the donor!!Well got the donor for a good price, have had two different shipping companies flake on us. Know my son and I are flying to Cleveland tomorrow to go pick it up ourselves. Not too mention I accidentally won an 09 LS manual on Copart that it looks like I will be paying a restocking fee. Not the way I wanted to start this journey.
07 SS SC manual, which I think may be the only way they come. 103K picked up as salvage. Hood and roof damage. It’s a northern car, looks like I will be dealing with some rust. But super excited to do this project.Details on the donor? We can see it's an SS.
I will try to bleed it this week and see if that does the trick. That or a slave cylinder. Figure I should start small.Good chance the clutch line has air in it.
It’s been a long day, I meant to say master cylinder.The clutch slave is inside the transmission bell housing, and requires removing the engine, and taking off the transmission.
So... not really a small start.
I haven’t looked that deep yet. It would be nice if Stage 2 was already done.Aftermarket intake, how about the pulley and injectors? I had a northern donor also, an oxy acetylene wrench will be helpful.
That is what I am noticing. Gonna have to order a new filler neck because it is really bad. I think I am going to just order a new fuel pump and avoid even having to deal with that part of the tear down. I am inclined to agree about the hubs.IMO if the donor lived its life it the rust belt and things are hard to get apart on the front, they will be impossible on the rear..... I wasted a better part of a day getting the tank out, not being able to disconnect the fuel lines the pump got toasted. I also left the rear hubs and calipers.... made it much easier to get the carcass out of the shop and loaded and who wants to have 120k mile plus bearings on the front of a land rocket!
Looked this morning, no such luck. The pulley for sure is still stock, I haven’t gotten to the injectors yet. But I would imagine still stock as well.Aftermarket intake, how about the pulley and injectors? I had a northern donor also, an oxy acetylene wrench will be helpful.
Note- found a diagram for the electrical for the boost gauge on the forum. Somehow during day 2 tear down the wiper fuse vanished. Installed new fuse and boost gauge works again. Now if I can just get a stronger feeling clutch pedal, I will be ready to work on finishing my tear down.First attempt at vacuum bleeding the clutch helped very little. Gonna try leaving the vacuum on it over night and see if that helps.
Boost gauge worked on first donor test drive, today while testing the clutch the boost gauge did not move at all. I checked and it is connected. Any thoughts?
