The air lift pulls the vacuum at the reservoir. It lets the coolant back into the system the same way. Remember that there is a over flow vent under the reservoir that you have to plug while doing this. I highly recommend this for filling any cooling system. I even used it to fill the SC cooling systemI assume you are pulling your vacuum via the reservoir, where do you pull the coolant in from? I've probably assumed wrong.
Airlift That I used
Amazon version
