Jim did you try putting the split collars into the steering rack as turn stops to prevent the rubbing issue?After running the Konig Tandem 17x9.5 , we have had a slight rub.
Edit : just noticed from the pic that it got the brake line as well.
Honestly, I've been telling people it doesn't hit, it was only after Jeff asked, that I went to send him a pic and noticed it had touched. I was just going to leave it alone and not turn to the lock and nail the throttle, but these things turn rediculously sharp, so I may add a stop.Jim did you try putting the split collars into the steering rack as turn stops to prevent the rubbing issue?
Steering Stop options?
Would be interested to try a set of the aluminum spacers! Just not sure how thick they need to be. My steering goes about 3 turns of the steering wheel....2 turn stop (I believe) would be about rightdfkitcar.com
Lonny, I'm Stull struggling with brake light issues, and now finding instrument cluster issues. I hooked up the stock steering wheel switches, and the only thing that works is the horn. When you did the wiring, you changed out the hhr dash connector and wired in the cobalt connector, do you remember, did you guys fire up the dash and cycle through any of the screens on the little display? They wull cycle when ecm/bcm initiated, but not when you use the info button. The hazards button doesn't work either.That is for the RPD option, the looped connector was original to your wiring harness.
If someone wanted the RPD option, the dealership would unplug the looped connector and plug in the RPD.
