Jm12
For today's incremental progress...
The RPD lives! I popped the housing open, took every ribbon cable off and anything else that wasn't soldered in place, gave it a quick wipe, reseated and here we are.
I'm amassing a pile of parts to start replacing this weekend. Plugs, coil packs, intake filter, catch can, replacement safety harness, hub and bearing assemblies for the front, fuel line and splitter to vent the tank, 3rd brake light to get CC working (purchased in Moab but never installed). I'm going to clean the MAF sensor as well and hopefully between that, a filter that isn't hopelessly clogged, and the new ignition bits, the misfire (?) problem will be resolved. I also managed to source a bushing cover plate for the shifter from an Amazon seller after multiple attempts to contact the original eBay seller went unanswered. $16 to replace the o-rings that are holding it in place currently seemed reasonable enough.
Once all that is taken care of the car should finally be back to baseline and then I can move on to actual improvements.
