Well it runs. Got everything hooked up tonight, refilled fluids and it fired right up.
The ZZP tune changed a lot it seems. The AFR at idle is higher, but doesn’t drop as much as I’d want it to under acceleration. Also the fuel pressure now runs at 70-80 instead of 50-60. I also don’t like how long the engine takes to drop back down to idle after blipping the throttle, but that was like that before.
However there’s one big issue. I’ve said before the car simply doesn’t get hot. Even at that last track session the highest temp I saw was about 190°.
Well with the turbo it shot to 220° in under 5 min. The fan kicked on and seemed to keep it from climbing any higher but I don’t like this setup.
I am running the turbo using the heater core lines. The turbo water “out” dumps right back into the engine, even though I’m almost certain that’s how the stock setup works I’ve gotta do something different.
