k.rollin
It really only fits over the halo bars; good thing it also fits in front of the truck's radiatorThat's a big one. Tell us where it will be mounted? Any forced cooling, fans being installed?
I like the rack. I’ve been looking for one. Where did you get yours?Finally got around to adding a roof rack
I'm still waiting for the plates, but the registration certificate arrived with the personalized number: AD LTNS = add lightness. Fitting as my donor was in the 1LT trim with a curb weight of 3,216 lbs and the build weighs in at 1,460 lbs.A cashier's check for $197.50 and some paperwork have just been sent off to Olympia so I'll have personalized plates representing WWU in about 8 weeks
Do you have an Ohm meter?So I'm finally getting around to wiring up my dash buttons so they'll actually do something other than make people snicker but I'm having some issues with getting the desired result. Part of the issue is not being especially electrically savvy and the other is extreme fatigue, so I'm hoping one of y'all might be able to get me straightened out. What I want is for the switches to be illuminated whenever the key is on, and for the function (horn, flashers, etc.) to work when the button is depressed. The current result is the switch illuminates as it should, but regardless of the button's position, the flashers don't turn on, horn doesn't beep, etc. I have been working to my interpretation of the annotated photo below. The sketch is my interpretation. Please tell me where I've screwed up?
View attachment 24120View attachment 24121
The actual wait time was closer to 8 months than it was to 8 weeks, but the personalized plates finally arrived!A cashier's check for $197.50 and some paperwork have just been sent off to Olympia so I'll have personalized plates representing WWU in about 8 weeks
Fitting as my donor was in the 1LT trim with a curb weight of 3,216 lbs and the build weighs in at 1,460 lbs.Add Lightness? Colin Chapman would be proud.
