Thanks again I can’t wait to get mine ordered! I’m looking for donors right nowMet up with @Pizzaman yesterday after work so he could check out a Goblin in person and get some questions answered. Took him out for a 12 mile rip as my car's first drive since last fall, and it sounded like it got him hooked. That, and seeing his Mustang account for the good news. The bad news is that my LR tire picked up a lath screw during yesterday's activities.
Can you send me photo or two of the bolt in harness bar? I'm thinking of fabricating one myself - I have plates fabbed and am almost ready to cut tube.Other recent mods that have kept me busy over the course of the last month when not working or helping my partner move/fix up their first house include:
• fabrication and installation of a temporary bolt in harness bar (temporary because it's only bolted in single shear at three points and I don't have funds available at the moment for a tubing bender so I can build a bolt in harness bar the right way)
• modification and installation of the Kirkey seat back braces (these have made the seats so much more rigid than only using the bottom mounts)
• installation of the parking brake kit
• finally wrapping the wiring harness (this is exceptionally more difficult when done in/on the vehicle)
• oil/filter change
• transmission fluid/filter change
• installation of the NLR diffuser
• alignment
Wednesday we'll be at Pacific Raceways in Kent for the Proformance Racing School's one day HPD course, so today and tomorrow afternoon work are/were for shakedown.
Have fun tomorrow on track! Weather should be perfect for you. Get some video to share too.Other recent mods that have kept me busy over the course of the last month when not working or helping my partner move/fix up their first house include:
• oil/filter change
• alignment
Sure, I'll post some after work today. Like I said, it's temporary/not ideal. As your chassis is uncoated AFAIK, if I were in your position, I would mock up my seats to establish the necessary height then just cope a couple pieces of tube and weld them in such that they're in the same plane as the main hoop.Can you send me photo or two of the bolt in harness bar? I'm thinking of fabricating one myself - I have plates fabbed and am almost ready to cut tube.
I'll post some after work. I basically just notched the plate to fit around the brackets on the provided harness bar, secured them to the bar with coated U-bolts, and ran (4) M8 bolts through the back of the seat and into the brace. The driver's side brace was also trimmed shorter to eliminate interference between it and the coolant surge tank.Have fun tomorrow on track! Weather should be perfect for you. Get some video to share too.
Interested to see how you did your seat back brace. Can you share a pic when you can?
My chassis didn't have bolt sleeves for the shoulder portion of the Cobalt's inertial reel belts, and even if it did, I get the feeling that they would be too high to mount a harness bar with my seats.The Cobalt seat belt bolt hole mounts in the B-pillar/roll bar are by default the correct height and have necessary strength to bolt a harness bar into. One additional bolt hole - same as the stock mounts with a reinforcement tube welded in - in the diagonal bar behind the driver's seat is where I planned to mount the harness bar.
Mock up with a scrap piece.
I was planning a 1 inch DOM tube (0.083) for the bar with 3/16 plates for the stock seat belt bolt locations. The plates will be thru-drilled to have the tube thru the hole and exposed on both sides of the plate for a double weld. The center bolt in the crossbar will be a welded reinforcement tube like the other thru holes. Using all grade 10 bolts with large reinforcement washers.
I would have to believe this is plenty strong and if it were to bend you have far more serious problems and injuries.
I found the stock seatbelt mounting locations to be significantly too high to use for a harness bar.The Cobalt seat belt bolt hole mounts in the B-pillar/roll bar are by default the correct height and have necessary strength to bolt a harness bar into. One additional bolt hole - same as the stock mounts with a reinforcement tube welded in - in the diagonal bar behind the driver's seat is where I planned to mount the harness bar.
What did you end up doing?I found the stock seatbelt mounting locations to be significantly too high to use for a harness bar.
That's about what I did too and it is definitely a bit sketchy. What size hardware are you using?I made this mildly sketchy setup.
