Fish scale?So far my emergency / parking brake handle has came apart inside 2 times. I'm tired of fixing it, I could buy another handle assembly from Lokar but do not want the same issues again. looking for a more permanent solution. I am leaning toward a linear actuator to work it. I found some nice small actuators at Servo City. I just have to figure out the amount of pull needed to apply the brakes.
It will have to be a good size one I feel like it would be 50lbs + would be my guessFish scale?
Is that a thing with the Cobalt's OEM parking brake? I noticed on my donor, the little half-gear piece was laying under the center console and there was nothing to hold the brake on.So far my emergency / parking brake handle has came apart inside 2 times. I'm tired of fixing it, I could buy another handle assembly from Lokar but do not want the same issues again. looking for a more permanent solution. I am leaning toward a linear actuator to work it. I found some nice small actuators at Servo City. I just have to figure out the amount of pull needed to apply the brakes.
Does yours not look like this? The second picture shows the pawl on top, inside the handle.Is that a thing with the Cobalt's OEM parking brake? I noticed on my donor, the little half-gear piece was laying under the center console and there was nothing to hold the brake on.
Deep sea fish scale...It will have to be a good size one I feel like it would be 50lbs + would be my guess
It would but!Wouldn't buying another pull handle be easier and cheaper? I haven't had a problem with my Cobalt parking brake handle.
Haha. Yes it should. I mounted mine a bit different for access which I am glad I did because of the luck I have had with the handle. I can get the handle out without removing the seats. Even though I put the 3M paint protector over it. Still it is all chipped up from the 5 point harness. If I go with the linear actuator to do it I will have to patch up some holes to cover the where the handle is now.
That one is not mine that is Bruce's.Sorry for my ignorance, but what is the 5 or 6 wire plug stuck in the end of the box under the lever?
