Metal Mech
So question for those more in the know. I’m working on getting the engine running correctly while I wait for the frame to get done. The engine runs smoothly but it cuts into limp mode/esc module error if it idles long enough or if I drive it for a few feet.
Based on the scanner the Crank and Cam sensors need replacement. I replaced the cam, I have the crank but haven’t gotten it in yet. I just ordered VVT sensors because they are a potential issue. Just figured eliminate that as a potential.
The other thing showing on the scanner is oxygen sensors error between first and second sensor. I know I have a leak between those two where the down pipe bolts to the manifold. Would that cause a limp mode error or should the other four sensors take care of the issue?
if I still have this problem after I replace all four what else could be suspect?
