ATMironov
I need to know in what position the clutch and brake pedal sensors are installed.
1. When the brake pedal is NOT pressed, is the sensor Loaded or unloaded? (Loaded meaning the spring in the sensor is trying to move the arm)
2. When the clutch pedal is NOT pressed, is the sensor loaded or unloaded?
This is only applicable to the LNF position sensors
This position is LOADED
This Position is Unloaded
Thanks!
Thanks!
