So, to further dive down this rabbit hole - I put zero's in everything and left the 15's column in tact, my car
did not appear to have DFCO removed - I was leaning out on throttle release.
I stumbled across this post and the guy explains the cells as such:
"For torque injector disable you put it to all zero except for leave the value of 15 in the far right column only from top to bottom. this will eliminate the injector shut off feature for torque control and the 15's keep it working for dfco."
So it looks like the 0's then 15's eliminates injector shut down for whatever torque control is (traction control?) and that the final column is indeed DFCO according to that dude, as well as a few other posts I read stating 15's to 0 for DFCO.
For the sake of my own personal experience in seeing DFCO appear to be disabled with 15's turned to 0 and
not disabled when I leave them as 15's, I'm going to keep it as I originally had it.
I suppose you could turn them all to 0's, though.
