Lokian's Extended Street Gob in Indiana - 10 LS # 251
Lokian
Updating the needs list.
Running list of items to do and figure out.
  • Clutch
    • clutch
    • throw out
    • resurface or replace flywheel
    • fix shifter... need new plastic bushings
    • need clutch pipe
    • master cylinder
  • Engine maintenance prior to install
    • rear main seal
    • timing set
    • water pump
    • spark plugs
    • O2 sensor
    • serp belt
    • Fuel Filter
    • Fuel cap
    • exhaust man studs
  • Drive train
    • Hubs
    • Bushings - press in
    • Tie rods
    • axles
    • output shaft seals
  • Seats (NRG PVC)- would like ones that I can slide back and forth - ordered
  • Lights
    • Rear
    • front
  • parking brake
    • parking brake tubes
    • ss parking brake cables
  • Rims and tires - ordered
    • tires - r888 or N05
  • Dash
    • Dash night ligths
    • Dash rear view mirror
    • Dash buttons
  • Paint
    • Axles
    • hubs
Lokian
Anyone have any idea if this is the passenger seat connector or what connector it is? Near the red bcm and had pink connection going to the pink split with the air bag connector and driver seat connector
19675
19676
Lokian
Last one... for tonight :cool: what is this connector.. my research says auto shifter but this is a manual car?
19693
19694
Lokian
I like your wire table....
I made my table high for standing comfort
Looking at yours I think a lower table and computer chair would have been better lol.
Sometimes it was nice with a chair and then other times it sucked to stand for a bit while pulling the wires out :). I had back surgery last year and some other health issue that left me with some damage nerves in my back, so you might like it more :)
pisco
I can understand that. Mine is high to prevent bending because I broke my back in a ladder fall in 2008, I was 24. Luckily for me I have avoided fusion surgery so far but it’s a matter of time.
Hope you are recovering well from your operation.
Lokian
its a process but it led me to pull the trigger on the goblin. :)
