Yeah, exactly.Just be careful when you say 60# injectors. If they aren't the same 60# injector then the tune may not function well since the flow data can be way different or totally unknown.
Your tune has worked very well with mine. Only real tweaks were to some codes I wanted to make go away.I have an 06 SS/SC with 2.9" pulley and 60lb injectors. Seems to run decent, I think 1 other already started from mine, not sure how far off it was for them. ZZP remote tuned stage 2 install on my goblin. I'll try to get the files later tonight.
I had the same injectors and a 2.9 pully on my car, it was dyno tuned somewhere before I got it. I can dig up my original file if you are still in needI have the ZZP siemens 60# part#107961-4
Post #2 up above will bring you to a list of LSJ tunes, or just click on my "Build thread index" in my signature line.Finally getting around to using hp Tuners can anyone send me their tune file.
I saw your post I'm looking for one for a 2.9 pulley and 60lb injectors, either the one bautsin or rttoys are using or bsinvestments. I'll send it to you also so you can add it to your list.Post #2 up above will bring you to a list of LSJ tunes, or just click on my "Build thread index" in my signature line.
LSJ tune for 60lb injectors and 2.8" pulley (Ghostknife)
LSJ tune for 82lb injectors, 3.1" pulley, cams, E85 fuel. (ncgoblin)
LSJ tune for 82lb injectors, z57 turbo, BRFS using the 515 EFI fuelab regulator, ZZP LSJ entry level turbo swap kit (r3drckt)
LSJ tune for 62lb split spray injectors, Borg Warner S257 turbo (lechliss)
LSJ tune for 60lb injectors, TVS supercharger, MAF only. (SACTX)
LSJ tune for 80lb injectors, ZFR 6758 turbo, BRFS, Stage 2 turbo cams, gfab2 electronic boost controller (ccannx)
LSJ tune for 80lb Siemens injectors E85, with ZZP Entry Level Turbo swap kit, K04 turbo (Sluggonaut)
LSJ tune for 42lb injectors, 3" pulley, GM Stage 2 tune. (Robinjo)
we were just talking about that tune, This should be it.I saw your post I'm looking for one for a 2.9 pulley and 60lb injectors, either the one bautsin or rttoys are using or bsinvestments. I'll send it to you also so you can add it to your list.
